  • harveypj
  • Stock "Wolfie" Smith Topic Starter
Does any body know if there is a standard stainless exhaust available for 30hp engines, like the 'Abrath' style available (see KK) but with standard tip configuration?
Failing that, does anywhere sell an accurate mild steel version? as original.
djkeev
HI,
I've never seen a stock stainless steel exhaust system.
The steel ones are readily available and reports are that they are a fine exhaust but here in the USA they are all imported from Denmark apparently.
As near as I can figure one manufacturer has the world market sewn up! Afterall what kind of demand it there for an exhaust system that fits a car made in the 50's ??
Maybe over in the "old" country, you have some OEM stuff floating around??
With enough money, you can get anything you desire custom made.
Good Luck
