samghia
Help appreciated
Just got my Oval MOT'ed thought it felt a bit under powered turns out have a broken Valve spring questions:
Source for push rod tube seals
Are the Valve springs univeral on beetles
Source for seals which go on cylinder head bolts
Thanks in advance.
Cheers Sam.
53 Oval
63 Ghia
64 Deluxe
71 Fastback
95 Golf Karmann Cabrio
Push rod seals are the same as 30hp So you would be better off buying a gasket set with every thing you need to do a top end.i am not 100%sure on the valve spring but i would guess they are the same as 30hp .You dont actually need to take the head off if you have the right tool but i would advise getting the heads reconditioned if it has done over 30,000.i have just rebuilt a 30hp for mine and the guides were shot .I am going to use a lead additive next time around.KK sell the gasket set /valves but dont know about the spring .I have plenty of old 30hp ones if you want to check the size.Just pm me if you do and i will send a couple.
Also if you are buying new valves make sure you check the collet halfs dont touch.I bought some and the taper is different on the valve so i had to grind the collet faces so they grip the valve.
samghia
Many thanks Mike received valves this morning.
Cheers Mark.
53 Oval
63 Ghia
64 Deluxe
71 Fastback
