Restoration advice, technical help, and classic VW discussion
If you want to improve oil cooling, and not risk mucking up you airflow, the safest way is to add an external oil cooler to your full flow filter.
gimmesomeshelter wrote:
It ought to be pretty easy to take an extra oil line off to a separate cooler.
Is the stock oil pump up to it? I've heard of people adding remote oil coolers and their engines ran hotter because the pump wasn't pumping enough oil around. I guess it depends on where it's located?
I think the pressure drops with the length of pipe?
The International Vintage Volkswagen Forums uses cookies. By continuing to browse this site, you are agreeing to our use of cookies. More Details Close
