I've a LHD July 1952 export bought from mainland Europe and I am contemplating a RHD conversion. The part that would stop me from doing this to most cars would be to have to chop out the dash and weld in another - this is obviously not an issue here, though I understand that the following would still need to be done (please let me know if I’ve missed anything):
- move steering box mount on front beam
- obtain RHD pedal cluster - are these the same right up to 1957?
- move the master cylinder (I'm going to replace the brake pipes anyway)
- move the light dipper switch
- move the steering column (the right hand side already has all the pressings ready to accept this - I'd obviously need to weld up the resulting holes on the left hand side)
- swap the speedo and clock pods over, extend the speedo cable tube and replace the cable with a longer one (I assume the speedo cable still runs to the left front?)
- should the keyed lock be on the drivers door – I seem to remember reading somewhere that on original RHD split beetles the drivers door had no keyed lock, it remained on the left as no other parts were available – is this correct?
I understand that to most countries this will devalue the car and that the car will always be a type 113 converted to RHD and not an original type 114. However I would have thought that the conversion would have little effect on value in this country (not that I plan to sell the car). I've owned a LHD Karmann Ghia for the last 8 years but would rather a RHD car.
I’d be grateful if anyone would share their opinion with me on whether to carry out the conversion. Alternatively, if anyone has done this themselves and could offer any advice, that would be much appreciated?
While I'm asking for people’s advice / help, I’ve also got a couple of MOT questions:
- Does everyone run windscreen washers? I know strictly it’s an MOT requirement but are the testers hot on this for such an old car?
- I assume that I can’t simply adjust the headlights to point to the left – do I need to get the headlight units from a pre 57 RHD car to maintain the correct type of headlight for a 1952 car?
Sorry to bombard you with questions, and thanks in advance for any input you can give.
Dan.
