thevideovolks
9 years ago
Looking to find a few bits for the 51, if anyone knows where to find or has anything please let me know.
I am after a
Gasket set,
Fuel pump rebuild kit,
Piston rings etc.
Any good places I should be checking out?
Thank you :beer:
Rod_vw
9 years ago
I have the following if they are of any use to you.
Piston Ring Set for 25bhp 1131cc
Part number SP109A (111 198 255) 2nd oversize for 76mm bore
These are New In Box comprising...
4 x 111 107 309 Piston ring, upper
4 x 111 107 319A Piston ring, lower (narrow face contact)
4 x 111 107 329 Scraper ring
£25 plus P&P
thevideovolks
9 years ago
Thank you very much, I passed this on to E's who is putting the engine back together.
I think mine are 74.96mm pistons though.
Rod_vw
9 years ago
Yes, most are standard size, these were intended for engines that were re-bored i.e. mostly factory re-cons. I just thought I would mention it in case they were of some use.
Cheers,
Rod
