Some tips for the linkage:
The balljoint on the pivot arms on the carbs. (both type-3 and 4) are in wrong position to be able to work with a centermount linkage so to make that work you need to weld a new location or make a totally new arm for each carb which locates the palljoint to appr. 10:30 oth the left carb and to appr 01:30 on the rightcarb at idle.
Like this:
(you still see the original balljoint, and the new balljoint is now located on the flatmetalpiece above it)
At idle:
Full throttle:
At idle here to:
Edit: Oh! and you also see the 20mm thick bakelite spacers I made for lifting my carbs some just to (hopefully) clear the aircleaners from the fanshroud and body... 😉
