No fixings under the back seat of Old Blue apart from a clamp and nut to hold the battery steady.
Old Blue wrote:
12v cars are different.
Old Blue
Rattletrap wrote:
I doubt there's any real difference in the battery fitting on a 1967 6volt and on Old Blue, a 68 12volt.
Old Blue
Old Blue wrote:
I still think that a tryout 12volt car section would be a good idea. There must be a few members that have complete stock 1968 on cars who would love to interact about them. Yet there are people posting images of non stock pre67 cars on some threads!
I took out Rattletrap’s seemingly tired battery as the engine continued to turn slowly. I then put it into my 1949 model export, which has not been touched for a few years now, so with any battery you’d expect a difficult time getting started. I removed the 49’s coffee can air cleaner and trickled a small amount of fuel into the carb. I turned the ignition key and unbelievably, it fired-up second crank.:smile:
Even more surprising is how the car went straight into a nice smooth idle with a little choke. Gentle accelerating produced no flat spots or spluttering. This original engine sounds so much less harsh than the later motors, and has a lovely idling tone.
I gave it a 20 minute running session to make sure it was fairly hot on switch-off – don’t want damp in the exhaust, which I believe is the original one put on at the factory when this low-mileage car was ‘born’.
Just how long is it before petrol becomes 'stale', the fuel in the '49 is several years old, but still does the job.:?
While I had the air cleaner off the ’49, I took a picture of the paper label still stuck to the fan housing since being put there at the factory when the car was built. It shows the new owner the correct fan belt adjustment. Small print at the bottom of the label has the print date of 1949. Unreal to think that this paper label has been there for over 63 years! I’ve never seen one that has survived before on any other car.:smile:  1949 Fan belt adjust label.jpg You have insufficient rights to see the content.
Old Blue wrote:
This has been done to death in this thread in General Chat and not relevant here on pre53.
https://forums.pre67vw.com/yaf_postst19128_Time-to-include-flat-headlight-12volt.aspx
Personally, although my interest stops at 1960, and I like things here as they are, it doesn't mean that later cars are not interesting to others. While flat headlamp cars are not something I would follow, it is a fact that there are some nice original examples around, and an original 1968 on can be more interested than a unoriginal lowered 67. Mike Peckham here has a splendid Marathon model that I know he'd love to air in an appropriate section.
Rattletrap wrote:
Stihl,a leading German small engine manufacturer.Claim in their literature,petrol starts to lose it's qualities from as little as three months.
GKL 7 wrote:
When I got Rattletrap after 14 years standing idle the fuel in the tank was useless. I drained it all out and flushed through with new petrol. You couldn't even use the old fuel to start a soaked newspaper fire.
The petrol in my '49 is a good six years old, smells a little stale but the car runs fine on it. I bet that it would be no use if put into a conventional modern car though.
Old Blue
GKL 7 wrote:
What exactly happens do you think? I assume that the octane rating falls away?
The lighter fractions of the fuel blend are lost namely butane and pentane reducing the volatillity. It kind of goes flat.
Old Blue
harveypj wrote:
That's interesting, and gives an in-depth answer rather than just quoting something.
How then is the octane rating made up? We all use petrol and know about the need for lead for example, but how many of us know exactly how the stuff is made up/refined. You hear of premium grades suitable for performance cars.
It does get a bit complicated, you might want to sit down
I do not claim to be any sort of expert but I have picked up a basic understanding during my 18 years working in refinery operations.
Petrol is a blend of HydroCarbons, molecules made up of Hydrogen and Carbon atoms ranging from butane (4 carbons with 10 hydrogens) C4 for short, up to around C12 (doedecane) in all their varing forms plus various addatives to promote stable burn and detergants. Butane is the lightest (an LPG) and basicaly wants to be a vapour from about 0 degs, so is first to escape. Petrol blended for winter/cold climates has a higher butane content.
Pentane (C5) is next.
Different fuel blends have different combustion characteristics, some will auto ignite prematualy in a rapid uncontrolled manner as they are compressed (described as Knock - can be heard as 'pinking') this is more severe the higher the compression ratio of the engine, some blends will be more resistant to this and can be burned efficiently at higher compression ratios that is favourable for higher power outputs.
The octane rating of a fuel is a referance number, awarded when its 'anti knock' characteristics are the same as that of a standard reference fuel blend.
2,2,4-trimethylpentane (an isomer of Octane) is rated as 100 and sets the standard. Our regular unleaded has a Ron (research octane number) of 95, equivalent to a blend of 95% Iso Octane and 5% Normal Heptane (heptane is rated at 0)
This is where it can get a little complicated, hydrocarbon chains in their simplest form are straight chains or 'normals' or in more complex forms as branched or ring chains known as 'isomers' . So in the case of our 2,2,4 above; a chain 5 long (pentane bit) with 3 branches (tri) 2 at the second link and 1 at the fourth link (2,2,4)......simples😬
isomers have a higher rating compaired to their normal brothers.
The the octane rating is not a measure of how much energy the fuel contains but its resistance to autoignition when squeezed.
The Beetle engine is a long stroke low compression engine (somthing around 6:1) so can run happily on standard petrol (3 star in its day), running high octane stuff will not give you any more power. A modern high compression engine with knock sensor/adaptive engine management will however burn it to better effect.
Thought I'd better mention that in the states they use a MON number (motor octane rating) same principle only tested / compared with the test engine at higher loads as well and then an average taken resulting in a slightly lower rating equivilent.
Old Blue
harveypj wrote:
Thank you for such good description Harvey, certainly that has helped my understanding of petrol. I wonder how many consider how the stuff is produced when they're filling their tank. Its great that we have people using these forums with such knowledge. I think that you could team up with Jollychuffy who gave such a fine description on my tired battery problem:smile:
May I add my two-pennyworth !
Assuming the confirmed health/efficiency of the starter motor I would first of all ensure all ignition components are fit, then check the actual ignition timing : a couple of degrees retarded and sluggish turning over and a reluctance to fire could be mistakenly blamed on the battery.
The traditional hand-held "Load" tester comprises a heavy metal spring or coil resistor mounted between two "Prongs" with insulated handles between which a voltmeter is also fixed. Pressing the two probes onto the battery terminals simulates the load that the starter motor imposes, the voltmeter indicating the reduced power available to energise the ignition circuit.
Two points about the load tester : The voltmeters are usually of a " Centre Zero " type, the needle swinging away from the prong on the positive pole of the battery ( Handy to check terminal polarity !) and most "Load" or "Drop" ( ie Voltage Drop" ) testers are stated to be suitable for use on batteries up to SIXTY ampere/hour capacity, lower than the capacities of six-volt batteries for VW's ! Accordingly, a low or poor test on a 6-volt VW battery is more-ominous than a similar reading on a smaller six-volt. This type of tester should only be applied for a similar time to that during which you'd expect the vehicle to have started.If the voltage reading continues to "Sink" after three or four seconds on a fully-charged battery then watch for a cell to "Short" or "Gas" ( And Smell !)
The best check for a battery's state of charge is to use a small volume/capacity hydrometer
which indicates the acid's specific gravity ( Small hydrometer because there's not too much acid in each cell from which to draw a test sample!). Avoid contamination by trying not to transfer residual amounts of acid from one cell to another.
At normal room temperatures ( 20 C to 25 C ) a healthy gravity between 1.250 and 1.280 is ideal. Readings between 1.200 and 1.240 indicate partial discharge and a charge-up needed but lower than 1.200 point to a flat battery and longer charge needed. Some hydrometers have colour-coded zones indication acid strength ( High, Medium or Low)
A battery will give a false load-test result if the gravity is below 1.240. If you have a variable charge RATE ( Not 6 or 12 volt ) charger ( ie High or Low settings ) it is advisable, especially in cold weather, to commence charge at a low amperage
There being only three cells to compare on a six-volt battery, variations in gravities are harder to detect than on six-cell 12-volts. Variation between cells of 0.1 s.g. or more after charging are usually indicative of a suspect cell which will "Gas" visibly when load-tested. After charging and prior to load test, remove the three cell filler/vent caps and blow across the battery lid to dissipate the explosive hydrogen given off in the charge process.
Always abide by the golden rule to prevent sparking an explosion ! Starting charge : Crocodile clips on to battery then switch on charger. When finished : Switch OFF charger then remove crocodile clips ! No unexpected sparking nor loud, corrosive bangs !
Off on a tangent, many modern sealed batteries boast a "Magic Eye" charge indicator. This is a simple optical float hydrometer device calibrated to float green when OK, usually yellow when part discharged and clear with a red circle or plain black when discharged. Bear in mind that this device only indicates the state of charge of that ONE cell, not the whole battery.
It was a widely accepted " rule of thumb" in the days of only moulded hard rubber batteries that for every degree centigrade that the temperature drops below freezing point, batteries lose Five per cent efficiency. Minus five degrees robs a battery of a quarter of its power potential, 60 amp/hr down to 45 and pro-rata onwards, minus ten equals half power !.
I personally have revived batteries from motorway-stranded lorries so flat that the electrolyte froze ! (It had reverted to water !). FLAT is not always FAULTY ! But there again, you can recharge a flat one but can't re-incarnate the dead !
In an emergency to get started in very cold spells you might consider taking the battery indoors for a warm ! Standing a cold battery in a bowl of warm and then progressively warmer water works wonders. I would not, however, recommend standing your battery on the AGA nor in front of your log fire - A spell in hot water within an inch of the lid or deck and an occasional agitation enabling thorough warming of the acid works wonders !
Hope my contribution is of some help . John aka Jollychuffy
This is all very interesting, but lets get the thread back on track.
But before we do, while on the subject of fuel, I'd like to ask harveypj why on the log book for my Routemaster bus, is the fuel (diesel) descibed as 'heavy oil'. What makes diesel work different from petrol :?
Mike, should it not have a strap over fixing?
These do not have a slot at each end for the spring pull-down clamps.
Rattletrap wrote:
According to the Bob Wilson book the springs were replaced with a metal strap in October 52 ,which coincides which zwitter production.
Mike.
https://www.thesamba.com/vw/forum/viewtopic.php?t=409293&postdays=0&postorder=asc&start=0
You may well be right Mike.But i wouldn't go on the Bob Wilson book,packed with mistakes.
GKL 7 wrote:
I have heard a few people say the same about that book and why i think its important to tell people where you got the information from.still a good read though. i suppose all you can do is use whatever information you have at hand and back it up with pictures from original cars.
The pictures posted on the samba do seem to suggest October 52 was relevant to the Strap being changed.
Rattletrap wrote:
Petrol is a lighter fraction of a barrel of oil typicaly hydrocarbon chains of between 4 and 12 carbon atoms long.
Diesel is a 'heavyer fraction or 'cut' consisting of hydrocarbon chains from around 9 upto around 21 long.
this range can be further split 9-16 (Kerosene) and 12-21 (diesel), type you put in your tank. There are tolerances on product specification and refinerys will exploit this to produce as much of the most valuable product at the time so some of the Kero may end up in the diesel or vice versa depending on demand. Kero overlaps with gasoline (petrol) so the same applies here.
Like I said before it gets complicated, product spec is not only density related but products may need to meet flash, freeze, vapour pressure to name but a few. There are not only 'isomer variations in hydrocarbon formation but varring levels of Hydrogen saturation all having different influence on finished product and blended acordingly.
Petrol engines mix fuel and air, compress the mixture to relitively low pressure and then control the ignition time with a timed spark.
Diesels first compress air to relitively higher pressure (about twice that found in petrol engines) generating high temp, fuel is then injected at the appropriate time and auto ignites.
I guess diesel just does not lend its self to spark ignition as its a lot less 'gassy' fuel, you'd just end up with an oily spark plug.
Old Blue
Here's a car that has done THREE times as many miles as Rattletrap...
https://news.sky.com/story/1144671/1966-volvo-clocks-up-its-three-millionth-mile
