davehikes
Putting the last of the dash and trunk area back together - The flasher/turnsignal switch has a brown wire with a spade push on and a bolt on terminal at the end - I am assuming this is a typical brown ground wire - why two terminals at the end and where does it go
Thanks to all that have gone thru this before me - your first hand knowledge is sooooo valuable
aircooled
Dave,
I also have a 67 with the brown ground wire and mine goes to one of the screws to mounting the speedo. The flasher I have has just one of those ground wires. Is it possible for you to post a picture of your flasher. The early 67 flashers are metal, followed by black plastic, and blue plastic cases.
