21 years ago
Whats the best kind of paint to use on my gearbox? I think that most paints just flake off the alloy don't they?
Thanks.
Rybeck
20 years ago
Hi, I'm in the process of restoring a 66 and I’ve just painted the gear box. I used hamerite black satin paint which i mixed 2 to 1 with thinners and sprayed with a gun. I could have used a brush but didn't want to see any brush strokes. The preparation needed was a full clean down with paraffin to remove gearbox oil and road mud then clean with brake clean fluid in a can followed by a wipe down with panel wipe which removes oil and dust before painting. The end result looks great!
671500
19 years ago
Ive tried hammerite..but as you say it flaked off within a year of use! That was despite followinga similar procedure to rybeck's!
I think FROSTS www.frost.co.uk do some paints and primers that would be suitable, but I dont ahve any experience of them!
19 years ago
Did mine with smoothrite about ten years ago and it's comming off too. :shock:
To keep my '58' true to factory I did not use paint, A good clean up followed by a thin coat of 'Dinatrol' waxoil to stop oxidation. It dries pretty well and gives a lovely factory look.
If you are referbing the box (strip down) you could get it vapour blasted to bring it up like new, then waxoil it.
