caslor
  • caslor
Hi
today i remove my 31 pic-3 solex carb from my AB(1300 but not sure if the previous owner make any adjustments) dp engine
it was so so so clean... ha ha :)
i use one new spray for carb cleaning but still wants cleaning...
is that product come out an in liguid or only in spray??
with what other material is alowed to clean the dirty from my carb??
i remove it as was lot of gazoline excauste and smell...
is that like it should be? the chock plate dont close... it close only there..
it is like the internal spring dont have enough power to close it...
any other point to look as i remove it..?
will place new gaskets and one bolt that was missing from the upper body of the carb
chris.james
looks like the carb has seesed up take off the choke aliment and clean with solvent celly or paraffin is a good cleaner.if you Carnot get it free dont put it back on .look for a new one. fuel you can lose your car.
