Judson53
Ive got a standard 53 RHD oval,im having problems with manifolds and acelerator cables,the problem is the cable wont reach!
Ive had the engine out last couple of days for a bit of a clean up,im told its a 30hp,i removed the inlet manifold,to replace gaskets and clean the case.I decided to refit the engine with a differnt manifold that came from another 30 hp motor i have for spares
When i final finished fitting it all back up again i found that the acelerator cable would not reach the carb!This manifold fits the engine better than the old one,the heater risers fitted a lot beter to the exhaust,so i would like to keep this manifold fitted but whats wrong with the acelerator cable
any idears much apreciated
cheers
Andy
mrmagyar
Hi Andy,
Have you trapped or nipped the accelerator cable while putting the engine back in? Or maybe it's got badly kinked somehow and ended up shorter? Get someone to press the accelerator pedal while you pull on the end of the cable to see if it moves back and forth freely. Like all problems it would be ideal to be there with the car to see what's up!
Cheers,
another Andy.
1949 Belgian Standard
1955 UK RHD De Luxe
Almost certainly a trapped/badly kinked cable as Andy says. Don't try and solve the problem with the old cable, get a new one.
Judson53
Well fitted a new cable still to short :evil: So iv fitted one from a 58 onwards bug witch has solved the problem
Any body got any ideas whats hapened
Judson53 wrote:
Does your car still have the original pedal cluster and carb?
Judson53
The carbs been changes to one with a electric choke,but i think the pedles are original
Its all sorted now though,well hopfuly
