I need part numbers for some gearbox components and wondered if anybody here could help. The gearbox serial number is AM3709430, I'm not certain but I think it may be a '67 gearbox.
The diagram below isn't necessarily correct for the gearbox in question but it helps me illustrate the items I'm interested in.
As a reference point, arrow/item (1)
should (I hope) be pointing to the 4th gear. It might be pointing at a different gear but in any event, it's the 4th gear components I'm interested in here.
The items I need part numbers for are:
(2) 4th gear needle roller bearing (just the rollers/cage).
(3) 4th gear synchro.
Any help or guidance would be appreciated.
I met a very helpful chap at Vanfest who specialises in
watercooled VW gearboxes. He has a good supplier base in the US and has offered to try to source these parts if I can provide him with VW part numbers. At the end of the day I don't care where they come from... if anyone else has any suggestions where I can get these then I'm all ears! :d
Andrew
195x Deluxe oval Beetle
Binz Doublecab
