Sambaguy
As I have seen before, Hebuller seems to have used at least two types of air filter, the T- filter and the Mushroom filter.
Did the early Hebs used the Mushroom and later used the T-filter?
If anyone knows which type of filter I shall use in my #134 Heb it would be great.
Thomas
reminou75
you should also be able to use a Cyclon air filter, don't you?
Thomas
Sambaguy wrote:
Your car had the mushroom style filter with the off-center hole. To make it sit a little more towards the fan house. That was needed because of the flat hood. The T-shape style with the extended tube to the carb was introduced later.
For the cyclon there wil not be enough space I think.
reminou75
usariemen wrote:
actually the T is bigger than the Cyclon... But the mushroom should suit better due to the flat hood.
reminou75 wrote:
The T on the Heb has an elbow on the bottom that places it further back.
Over the top of the fan housing,no
A cyclone will fit on a Heb,but you won't be able to close the decklid,not a lot of point really.:wink:
Here are the three possible ways.
I prefer the 3th option !:wink:
Etzhold1 wrote:
Thank you Guido!
Atleast if you mean to say that heb623 will be equipped with those!!!:shock:
Sambaguy
Yes!! I have now found a correct air filter for my Heb. It is a Mushrom filter with the offset hole. A Huf VFI june -49 carburator will also be mounted on the 25 hp engine.
Thomas
 mushrom filter2.jpg You have insufficient rights to see the content.  Mushrom filter.JPG You have insufficient rights to see the content.  Carburator 49.JPG You have insufficient rights to see the content.  carburator 49 2.jpg You have insufficient rights to see the content.
Helloooo.
You scored the real thing there...It's like hens teeth you found.
That is a rare item. Only a handfull are made and were replaced by the T-filter.
Congrats on the score.
Greets.
Andy Sparks
Etzhold1 wrote:
I have option 3 in my bug at the moment. OH yes what a great engine goes like stink
