There where two styles in the Hebs.
The first ones during 1949 had a quite simple hole in the quarter panel and from the rear
the semas where held by the same costruction that you find in the sedans to hold them.
This way was a "open door" for water to get into the car. So they changed in 1950 to the style with
the closed box from the rear as pictured above. That was welded all around and no more water was able to get in.
All in common had the Hebs the smooth outside with no box visible as it is at the Karmann ones.
I can post pics tonight if requested.
