Hi, I have done quite a few now, you need to warm up everything really, hot water is not ideal as then you are playing with wet rubber and also potentially trapping water in the groove where it will struggle to escape once fitted.
If you are in the garage, get some heaters on, get it nice and warm in there, this job is made harder than usual doing it in Jan!
Leave it on a radiator for a while, but it will cool quick if the garage is not warm. It is not an outside job at this time of the year. You will only break the glass trying.
1. Get someone to help tap it in. A screen is a 2 person job.
2. Get the right type of cord not string so that
A. you dont cut the rubbers and
B. the cord does'nt break mid job.
3. Use KY jelly, it really is the best for the job! washing up liquid is messy and salty and will do the job but depends how much you care about what goes on under your rubbers after they are fitted.
This recent thread from the Samba is REALLY useful!
samba windscreen fitting link (ps. Also always worth double checking the rubber you have been sold itself is the correct year one. They are very easy items for less knowledgeable parts suppliers staff to get mixed up! :d)
