Did anyone follow up on the auxillery lights?
I'm revising the rear lights on my Lowlight Ghia which were never intended for UK use.
At the moment the top bowed portion, which in normal UK lighting would be the indicator, is currently the sidelight and brake light. The lower part of the rear light is a flat red panel and carries the indicator.
In normal daylight the 6 volt indicators are nearly impossible to see, especially as they occupy the lower half of the light panel which most people expect to see the side/brake light.
In tight situations in heavy traffic this leads to confusion.
What I intend to do is swap the indicator to the top and the sidelight to the bottom. However because there is no room, as you can imagine from viewing the picture, for the larger double filament bulb under the flat lower panel, I will need to source an auxillery brake light to sit on the top of my rear bumper.
I'm thinking of using one of the rectangular Hella lamps. Anyone know where I can find one or options that will give a similar size lamp.
