On our Oval I put on two original style metal reservoirs, there are a couple of different types but they're only very slightly different - on one the bracket has two bolts, the other has one bolt and the base slides under a tab. I've used one of each (out of luck rather than judgement), the original was a one bolt bracket, then the new one just has two bolts on.
However, the tricky part was that instead of the metal brake line running straight into the top of the single circuit master cylinder - the dual circuit master cylinders use a larger style rubber pipe - so you have to configure some way of attaching the thinner hose to the thicker hose. I tried a couple of different methods which didn't work out, in the end I got some 8mm bar and drilled it to fit the smaller metal pipe on the reservoir and carefully welded it to the reservoir, then I ran the larger rubber hose all the way.
On my cabrio I got a '67 only plastic reservoir that sits in the original position behind the spare wheel, but again it's the same problem of small pipe to large pipe on the master cylinder. I used the same technique of pipe/bar and made some adapters.
Hope this helps!
