OVAL_POB
19 years ago
is there any way of unlocking my door handle with out the key any help would be apriciated cheers MATT
19 years ago
Not too sure with an oval but this will work on a later bug:
If you can get into the front compartment you may be able to remove the glove box and open a door from inside?
:roll:
OVAL_POB
19 years ago
thanks but im not on about getting in to the car,i can get in the car but there is no keys and the handle is locked.i took the handle off and can not figure how to unlock it :?
OVAL_POB
19 years ago
its gota code on the back of the handle if thats what you mean
19 years ago
I believe oval key numbers start with SG or SC? The key number should be punched into the handle and on the ignition switch.
It should be the same key for both but either the door handle or ignition switch may have been changed so they no longer match.
I got some keys cut from the lock numbers by /Gabriels VW Garage
Accepts PayPal and keys arrived fast, no problems.
https://www.vwtrendsweb.com/tech/0112vwt_locksmith
Hope this helps.
OVAL_POB
19 years ago
cheers mate Appreciate the help 😃
