Hi thought I'd give you an update
over the past few months I have been collecting parts (thanks 55 Kab for brake advice)and working lots of overtime to pay for them!!
and have removed all the under seal and tar board from the floorpan:
This revealed nasty repairs and corrosion on both rear corners:
So I bought a welder, taught myself to use it and attacked the pan:
Both sides are now finished it's not brilliant but it's better than it was,the pan should be off to powder coat next week, whether i'll have the balls to weld the shell is another matter:?
All the suspension was stripped down and is now powder coated:
Started stripping under seal off the shell at the weekend, amazing what you find!:
Todays job was tear down steering box which showed some severe wear on the worm shaft
So I have a few questions :
1 Anyone have a spare worm shaft?
2 Are the seals for the steering box still available?
3 The short track rod ,as the ends appear to be swaged on, I assume they cannot be replaced? what do you do for new ones?
