Our 60 is giving us a bit of trouble.
He doesn't like to start and can take quite a bit of cranking to get the motor going. Its easier since we fitted a choke cable that actually works, but the main problem is (I think) the starter motor.
More often than not, when the key is turned the engine cranks a couple of times and then there is a loud whirring noise - as if the starter motor has disengaged. This can happen time an again, and after some persistence the engine will catch and actually fire up.
Is this a common, recognised problem and what is the actual cause/remedy?
The other problem is sometimes it just cranks and cranks but won't fire (I've fitted new plugs and I think its had a new distributor cap in recent years) to the point where the engine gives a mild clunking/popping sound (still without starting). The engine has done about 53k. Any ideas?
When it's running the engine seems fine.
TIA
