The appearance of a Bus handle is the same as a Bug handle. The Bus handle has a part number starting with 211, the Bug is 113. The difference is in the lock cylinder since Bug and Bus use different key blanks.
The finger that actuates the lock in the door should be the same, however, I have seen a second, very rare version of finger that is shorter. Can you post a pic?
