Ivan
  • Ivan
Has anyone got a contact for either seals or rebuild kits for 16mm four bolt rear wheel cylinders? Any leads would be vewry helpful.
Cheers.
cupa65
Hi
Try PRS in Billericay 01277 630099
Ivan
  • Ivan
Hi
cupa65 wrote:
Cheers, will do!
cupa65
Hi
Think Peter Ebling has them listed but they're not cheap:cry: :cry:
He's sorted,and it was cheap:wink:
rob66
Hi I am also looking for these where did you get them from in the end
rob66 wrote:
I sent Ivan a complete wheel cylinder.
So it wasn't determined in the end who stocked the seals.
Is it 16's or 19's you are after??Could help with a 19 complete wheel cylinder(NOS)if you are in need.
rob66
HI Basically I need both all 4 cylinders have been sitting in a pot for the last 10 years and the rubbers are breaking up. I think I have sourced the 19mm seals but i am not having much luck with the 16's. I really want to try and keep the old cylinders if poss but otherwise I would be interested in the cylinder that you have thanks. The car is June 1950 so it 16mm at the rear and 19mm at the front
LMK via PM if you don't find yourself some seals.I had a pair of 19's and a pair of 16's until recently now just the one 19.
