I won;t trash talk any suppliers on a busy thread, but I've been let down twice now trying to get hold of some from the only supplier in the UK that seems to have any.
I did however double check today, and have been assured that they went out eventually last night so should be here tomorrow.... fingers crossed.
If I'm struggling, I very well may give you a shout though - cheers!
First run out????? Now there's a question.
There's still loads to do, and I'm sure it will be a never ending project with the car getting better and better without actually being restored as it goes.
So, in that vein, I must make it my priority to get it on the road and safe first so it can be used and enjoyed, then do all the other minor work as time goes on.
As I see it, the jobs before it can be MOT'd / Registered are as follows:-
1)Re-fit axle tubes, starter motor, bushes, seals, mounts etc for transmission.
2)Clean and protect rear 'under carriage' bodywork and inner wings etc.
3)Replace rear brake flexi hoses and inspect hard lines - replace as required
4)Replace all perished rubbers and grommets in pan and frame horns as required
5)Install transmission
6)Rebuild rear brakes / hubs / seals etc.
7) Fit new BOGE rear shocks
8 )Install engine + final checks and set up
9)Fit NOS heater cable and set up correctly
10) Rebuild front brakes
11) Bleed and set up and adjust all brakes
12) New BOGE front shocks
13) Fit new flexi fuel lines, OG fuel tap/grommet
14) Install fuel tank and new seal
15) Test engine
16) Check all electrics and probably rebuild semaphores, replace bulbs etc
17) Fit NOS door mirror
************** Aim to be at this stage before the winter is out....
18 ) MOT
19) Register / plates / drive / enjoy
20) Attend to dents on bodywork with dolly/bag/experienced panel beater/skill etc
21) Remove last few bits of touched in paint to leave it 100% all original paint
22) Have drivers seat stitched in a couple of places where the piping has come away
23) Clean and detail it to within an inch of it's life, then protect with wax sealant
24) Own and enjoy!
25) Politely decline offers to purchase my irreplaceable pride and joy
