Hello,
Advise:
Be aware that the aluminium body sits on a metal frame. Where the alu touch the metal you can get bad corrosion causing the alu getting thin and brittle. ( read useless) in that spot.
Be aware that all parts are there as you will have difficulty to find replacements.
Bumpers, trim, small parts...etc. And in case they are missing...have to be recreated.
The rear window is sort of plastic. Most of them brake or get yellow due to sunlight. Replacement announced.Finding the window will cause difficulty.
Did you took a look at the registry with picts on the forum here? If the car is there you should as arround what the condition is. Best thing to do, asking someone who knows about Rometsch cars: owners, restorers, and Collectors.
Best regards and succes. And if you buy it...post some picts. Thanks
