i had a judson on my 30hp engine for a while, and i would not do it again....
it is a nice thing for a display, but not for use....
if you do not use the higer power permanent it might work, if you use it frequently to push the gaspedal or to be faster on the autobahn... wrong thing to play.
Yes Andi likes to extend the range of the 30hp and of course there's nothing wrong with that but with the Judson you have to understand what it was designed to do and for whom the original kit was aimed.
The Judson Kit was aimed not at the motorsport enthusiast but the average VW owner who wanted to make everyday driving of their underpowered 30hp VW a little easier. They could have used a more efficient carb but that would have made it more expensive so they stuck with as many original VW parts as possible.
Judson guaranteed their kits would not break anything as long as you stuck to their installation instructions. Basically they said we have developed the kit to suit the standard unmodified 30hp engine, any changes you make to the original engine apart from adding our kit will invalidate the warranty.
Andi's problem and Peter Neilsen's were the same...running lean at high speed and this is where the Judson has a failing, not the Judson itself but the Solex carb which doesn't meter the fuel mixture consistently enough. Lean running produces extra heat and you don't want that heat in a Supercharged engine. Result?; hole in number 3 piston and burnt exhaust valve.
Time and again you see people asking forums what they can do to their 30hp engine to get
more from their Judson set-up. The answers flood in and
nobody mentions changing the carb.:roll:
Solution?
My driving advice if you are running a Judson is to drive your car like you are driving a 30hp...drive conservatively and it will repay you with a reliable vintage ride that is fun to use and good to look at.8)
Did Judson get it wrong? Not at all...they sold over 70,000 Kits for the VW alone...they wouldn't have done that it they ended up cremating your engine.
