I see 2 solutions in the photo's to hold up the plastic clear lens.
First one is a bracket, witch doesn't use the original 4 tiny drilled holes.
Second uses these 4 holes, but then the clear lens must also be drilled?
In my humble opinion, shouldn't there be some sort of U-shaped bracket used by Hebmuller to bolt on to these 4 holes and avoid drilling the lens?
Proost! Peter.
