lutty
  • lutty
I am looking for a 30HP VW engine pulley, any leads would be great
thanks
lutty
  • lutty
Help required. Has anyone got a picture of an original VW 30HP pulley, interested in the correlation between the keyway & timing mark cut out
thank you
Piet
  • Piet
Both are notched at 7.5°.
Left pic is off an industrial 30hp, Right is a 54.
Same notch location.
Beware, the angle of the camera may distort the location of the notch a bit. Did my best tho. If you need more just shout.  poelie 002 (Small).jpg You have insufficient rights to see the content.  poelie54 (Small).jpg You have insufficient rights to see the content.
Proost! Peter.
lutty
  • lutty
Piet,
thank you for the pictures, mine is a 54. This will help in purchasing the correct one
regards
