pipvan
  • pipvan
Can anyone tell me the correct configuration that I should have on my rear brakes. I appear to have split bug backing plates with the 4 mounting holes for wheel cylinders and 2 springs as the hard wear. Should I have 2 mounting holes for wheel cylinder and a 3 spring configuration ??
57 Oval
62 Bug
65 Split
Lost64
Hi Pipvan,
I've just been rebuilding the brakes on my '57 Oval, so I have some first hand experience! You should have the three spring configuration, one spring across the shoes beside the wheel cylinder, and the other two going from the top and bottom shoe respectively the little bracket where the star adjusters are located.
"Every little bit helps!"
Gavin.
pipvan
  • pipvan
Thanks Gavin
57 Oval
62 Bug
65 Split
vwJim
Hope you don't mind me jumping in on this thread.
I've just bought a job lot of parts and in there are some backing plates with 4 holes for the slaves and others with 2 holes.
I won't be needing them so need to know what years they are for so I can advertise them correctly. thanks.
pipvan
  • pipvan
Vw jim i belive they are for a split bug with the 4 mounting holes for the wheel cylinders, (anyone correct me if im wrong).
Phill
57 Oval
62 Bug
65 Split
