yes you can do this,if after originality swap the front suspension over with original one as latter have steering damper fitted unless you want better steering handling and not a fan of every bump on the road. you may have to get a different transaxle mount where the tail bolts up as im sure they slightly differed over the early years so just check
jason1955 wrote:
What´s up with your original pan? You may hurt the value of the car as it´s not going to be original any more. Are your pan halfs rotted out?
hithere not the best,i have tryed to find a 54 floor pans but the words hens teeth come to mind, this is why i was hopeing to go for a later,chassis, thanks for your advise and you are rightthanksken
slammed54oval wrote:
The International Vintage Volkswagen Forums uses cookies. By continuing to browse this site, you are agreeing to our use of cookies. More Details Close
