DarthMJH
10 years ago
I am currently restoring my 1960 Beetle and need some rear crossmembers.
https://restorationpanels.com  which again look very good.
However I cant find the cross members themselves. I've looked at KlassicFab but they do not produce them either.
Any ideas where I can source some from?
Many thanks
1960 Karmann Beetle Convertible
andylham
10 years ago
sadly to date there are no correct reproduction 56-60 complete rear cross members.
take a look at my "100% STOCK" 1956 ragtop restoration it shows how I made them myself and may help you.
https://www.thesamba.com/vw/forum/viewtopic.php?t=605718
:thumbup:
DBKUK
DarthMJH
10 years ago
:thumbup:
Originally Posted by: andylham
I am very impressed, great work !
10 years ago
Andy's right, but I would suggest buying a pair of Mika's corner repairs (as per you pic/link) is a good starting point to fabricate the rest of the complete panel. Most of the awkward pressings are in that corner piece.
andylham
10 years ago
no disrespect to mika but there are a few different 56-60 rear cross members his has the hump by the heater tube some don't have this dependent on year and where cars built.the side box section is very brutal kinda like a IGP pressing same goes with the rib the pressing is not clear.
that said,it all depends on your budget and the build your doing and how anal you want to be. :smile:
I forgot to say if your car is a "60 one year only" then that area/pressings are different and has only one bolt hole.
DBKUK
DarthMJH
10 years ago
Correct mine does only have one hole. I was going to weld up the other hole in Mika's.
I will study it more carefully to see what else is different.
vwhelmot
10 years ago
This is the only way to get a correct year rear crossmember
I bought a pair of correct year body cut members of the samba. The way they had been cut meant I had to find some new ends.
This is how it arrived
I drilled the spot welds out to separate the outer strengthener and I bought a pair of oval era panels from virtanen
I cut the new panel to suit
Metal finished
Now I have the correct width to make a new inner section.
I made a new end
Bead blasted
Plenty of weld through primer and spot weld them together again
Lots of work but if you want a 100% correct shape panel , this is the only way to go.
