So...
Having lost its numbers in its long hard life, it's been difficult to date the car. Definitely no crotch coolers because the inner footwell panels are intact, no ashtray in the dashboard, so we thought it was an early car. After pulling some carpet out and assessing various things, I noticed that the fuel reserve lever hole is offset to the right (and the curving swage line goes all the way over). This was changed in Aug '49 when the large fuel tank was introduced - which means that this was a small petrol tank car! Also note that there is no indent for a RHD dimmer switch.
I then had a closer look at what was cut away to make way for the 70's petrol tank and sure enough you can see where the flat panel at the side of the small tank has been cut and folded over. So that has changed things somewhat. I have recently bought a small tank from Ritchie at KK, he said that in his 30 years of trading VW parts, it's probably the 2nd small tank he's had, which shows you how rare (expensive) they are.
It currently appears that there are no other surviving small petrol tank Karmann Kabrios and if thats the case then this would be the oldest surviving (barely) model. 😮
