beefykeefy
Bought some rear inertia belts, can anyone help with the location of the welded bolt mounting position on the C pillar? HELP!!!
Welcome to the forum! 😃
The rear top mount should be at the same height as the front one, just behind the side window frame.
You can see the plastic screw cover on this '67.
 6417.jpg You have insufficient rights to see the content.
beefykeefy
Thanks for reply and piccy. 😃
I see you live in Bucks, I live in Herts - anyone you can recommend for welding??
I would give Hayden a call at Panel-kraft, on the A41 near Hemel.
https://www.panel-kraft.co.uk/
He's very busy (as all good VW specialists are) but worth a call.
simonhanloncole
I don't think all 67's are fitted with the factory mounts?
