  • Chris
Well, yesterday we managed to fit the handbrake to the chassis and get the bar connected that fits through the tunnel...... 😃 😃 😃
But then found.....
Gearbox oil in one of the brake drums...... May need to put new seals in there.. :cry:
Managed to shear a bolt that holds the handbrake cables to the centre bar.. :oops:
And worse of all, found that the solid petrol pipe coming out of the rear of the chassis has snapped... :shock: :cry:
Ah well, that's life 😞
That always seems to be the way!
A mornings work end up taking two whole weekends! :?
  • Chris
Last night I managed to...
Remove the sheared bolt from the bulkhead and clean up the thread. 😃
Replace the handbrake cable that had the split in the conduit. 😃
Anyway a question...
What size is the thread on the handbrake cable ? I've got a couple of 6mm nuts but they don't seem to go on smoothly. :? Is it a metric thread or imperial size ?
That's always the way. Can't wait to see it finished Chris.
  • Chris
Don't get too excited, it's not going to be in the same league as George's cabrio... 😞
To be honest, I can't wait to see it finished either, if only for the wait I've had with it... and to stop spending money on it. :roll:
Anyway, back in the garage when the Mrs gets home from work... 😃
