Its is always cheaper and better to start with a good/rustfree as possible van, but not everyone is able to outlay £5k+ in one hit so buying a project is the only option.
There are plenty of project Bays around though, try and find one closer to home as you dont have transport. ( Not just on Ebay)
You need the person doing the welding to see the van or lots of detailed pics at least of all the areas that are always! rusty, before you buy it!
As six-o-one says people usually forget the high cost of replacement panels/metal/parts. Always spend more on genuine vw metal over repro if available/given the choice, it will save labour time and give a better result.
But if you are getting reliable! non-costly welding, you could probably do everything else yourself. Its a steep learning curve but do-able so long as you dont expect a show van at the end!
You can prime & paint over each new repair as it is done with a brush to start until all welding jobs are completed. Dont be tempted to cut all the rot out at once! You need to retain buses shape/rigidity! work around it 1 or 2 rust repair jobs at a time.
It will cost more than you think even if you do it, but you could find it hugely satisfying!
Another thing, buying a bay camper, buy a bus that was converted into a camper from a factory 'minibus/ or with factory side windows rather than a factory panelvan converted later, as the 'converted side windows' are less desirable/attractive. ( As your ebay example!) Unless the van is an absolute bargain!
Try to avoid home converted vans in principle. Stay with identifiable conversions. Private sellers are not always so honest with this! This is a hard one to spot but worth the extra care regarding future value.
Get these books (vw books sell them) They are both excellent reference!:
