louis
  • louis
is someone has the okrasa manual, need to have info to build it.
thanks,
Louis
the love of my life:
1954 oval 3 fold
okrasa tsv 1300
83mm p/c
69.5mm crank
isky cam
Andy Sparks
No manual but a bit of experience, what questions do you have?
louis
  • louis
was wondering if i use the same rocker arm as original and where to run the oil line from the fram.
thanks,
Louis
1954 oval 3 fold
okrasa tsv 1300
83mm p/c
69.5mm crank
isky cam
joe h.
Louis, you should have asked The Man. He would have printed you out a set.
I could send it to you, I also have the Operating and Maintenance Manual, and the schematic for clearancing the piston skirt and rods for a stroker crank.
The best thing to do is research. I have read every thread in this forum (thanks guys)
Also do a search on The Samba
Here's a couple of links for ya.
https://imageevent.com/mrokrasa
https://vwjudsonregister.tripod.com/stephs-oil-lines.htm
BTW, the stock rockers will work fine, as well the springs if there in good condition.
For the oil lines you use a special fitting for the oil sender and one of the distributor bolts.
Look at the pics on Mr Ruiz's site closely and you can see them.
1954 oval
louis
  • louis
thanks buddy!
1954 oval 3 fold
okrasa tsv 1300
83mm p/c
69.5mm crank
isky cam
Andy Sparks
you can get good oil lines on the judson registry site, not a fan of the bee hive idea, as you will suck in warmer air.
