58BUG
  • 58BUG
20 years ago
It started today, my 58 bug has started making a squeaking noise when I turn left at slow speed, especially the more I turn the steering wheel. Anyone know what this might be, bushes, dampners, bearings??? It only happens when I turn left??
Moby5153
20 years ago
Try disconnecting the speedo cable at the wheel first, it may be that, and you could check the wheel bearings at the same time.
58BUG
  • 58BUG
20 years ago
Mmmmm I can't really see it being the speedo cable, the sound seems to be coming from inside, possibly bottom of the steering column. Any ideas??? 😞
20 years ago
if its a constant squeal when you're turning left, then I'd say its more than likely a wheel bearing.
Moby5153
20 years ago
Quote: Mmmmm I can't really see it being the speedo cable.........
Well for a check that's going to take all of 5 mins to do, I would have thought it was worth it, but that's up to you of course......
