Ok, dumb question - my 58 has a fuel tap and I have no idea which way it should be when the tank is full, and when using the reserve?
Also, how much is normally left when in the reserve? Does the engine just cut out on you when you get there, and then you turn the switch and you can restart again ok?
I have a dipstick too, and not planning on running into the reserve if I can help it, but it would be nice to know how it all works incase I do need it :)
Ta! :d
