Hi All ..would like some thoughts etc on plan ive got with my car...open to suggestions advice etc.... (Though reading some of the threads on here its getting a little nasty?! :? )
Ok I’ve got a LHD 1955 oval ..(August/September build according to the numbers and later handles and quarter lights....) ...i didn’t lower it! but im ok with how it sits at the mo to be honest....have the original front beam and wheels though.
Its got its original engine but has an end float of 0.35mm ...would like to make it a more “daily driver” for the use of my girlfriend and myself..so aiming to factor in some reliability and safety.
Pictures link here
https://www.flickr.com/photos/35783201@N06/ Ok about to replace the engine with a 1641 plus swapping out the box for a like swing axel modified to fit also using the drive shafts from the original to keep the wheel base the same... the originals will be kept and stored, with the idea of overhauling them next year...this also allows me to fit 12v electric ...with discreet tiny led indicators fitted front and back...
Next the paint and body repairs.....it’s not the original paint ..! someone in the past has put down a light coat all be it in the original colour....unfortunately some else has then rubbed through to the metal in some places to give a false ageing effect?!?!... so i have no real qualms about getting the exterior restored to its original colour ....interior paint is fine and will be left as is....
As for rust/rot there doesn’t seem to be much?!?...the wings are worst affected, but the guy who i know and have seen his welding (its good!)says they are easy to restore “let in” metal and get them back to original...
Safety belts and interior trim..... ok here thinking of fitting either lap belts front and back(no need then to drill in the B pillar) or harness front and lap belts back ...same reasoning....
Carpets where they have worn through etc will be matched up and replaced with new replicas only where needed (originals stored safe)
Golden rule for all the above its to not alter the original car in any way (bar small holes for the lap belts in the floor pan) and anything removed from the car to be stored safe...
Ok that’s about it ...sorry to bore you all, but if you have any thoughts advice etc ? :d
