jrusk1957
I have a 1959 Convertible I just bought, it is leaking oil and I think I found out where it is coming from but it is kind of strange. There is a cable that I believe was for the heater box that is coming out of a small shaft, it looks like there is oil coming out of it. Is there supposed to be a grommet that the cable goes through? I put a small amount of gasket sealer in the hole and it looks like it stopped it. It had new axel boots put on and that is the only other place that it looks like it might be coming from. Would a small tear in the axel boot cause a leak also?
Jim
These can be a nightmare to track down, but I´d give the engine a good old going over with the jet washer and get it really clean. Makes life easier. If its from near the outside of the motor it could well be a rocker cover gasket.
jrusk1957
Thank you. Yes, have jet sprayed the underneath several times, still looks like it is coming from the boot area (on the right rear) or that hole for the cable. It is driving me crazy, LOL. Still looks like there should be some kind of grommet or seal where that cable comes out.
The oil gets blown all over the place by the cooling fan. Could be coming from anywhere!:beer:
