simonhanloncole
Can i fit a dual circuit master cylinder in a 67 bug. I propose blue brake hose with y piece to take fluid to each circuit and brake pipe fittings are obvious but what about the pedal push rod can i just use this as is in a dual circuit master cyclinder.
What to do it to improve safety, going to be doing this beuty up as a 50 mile a day commuter car need to use it before someone bans old motors from the road.
Simon
Simon
simonhanloncole wrote:
yes, you can fit one- no probs. Rather than the Y-piece from your reservoir, Karmann Konnection have some US-spec dual circuit reservoirs in stock that look the same as the early single circuit ones.
