This is a problem for all of us with early cars that have cloth seats โ€“ rust penetrating into the cloth at the top of the seat backs along the back from the rusting steel frame inside:?
You cannot really take the cloth off to get at the rusting metal of the frame, and also rust stains cannot be removed from the cloth :evil:
Answers appreciated for both prevention and cure ๐Ÿ˜ฎ
Rattletrap โ€“ the Volkswagen Beetle that has covered an incredible mileage equivalent to over 35 times around the planet :omg:
Running nifty since 1950โ€ฆ the King of Volkswagens:beer: Why not make friends with this famous little VW โ€“ he's on facebook!
Wondering if the cloth would be possible to wash with oxalicacid without damaging the cloth...?
Oxalicacid is a weak acid that reduces (and disolve rust, iron(III)oxide). Could be worth a try if anyone would have a piece of rust damaged cloth that is going to be unused anyways. I might have some pieces somewhere too. Have to check this out...
The HebsterWerks.
Hebster52 wrote:
Please let me know:wink:
Any info on stopping the stains appearing or spreading without taking the seats apart:?:
Standard split wrote:
They can infact, John.
There used to be(maybe still is) a Product on the market called "DIRT DEVILS",a range of approx 6 different stain removers for fabric,one was especially for rust.
Roy Worsley used it when restoring his '51(ex Roy Worsley/Keith Seume/Flat 4 car)to very good effect.
Excellent, George :beer:
Now, do I have the courage to remove the seat coversโ€ฆโ€ฆโ€ฆ:?
They'll have to come off to do the job, and to paint the frames.:roll:
Bengt H
Seatcovers are easy to remove. If you wash them i water they may shrink a bit, try to strech them before they dry and maybe when they are half dry to
'49 showing signs of age? :twisted:
Yes, he's preparing it to sell to George. :lol: :wink:
1958ghia
You could use noiseless "silk film" when you put them back together it might work as a plastic barrier to stop any rust coming through in the future.
rjbinnie upholstery
'Fraid it is the '49 ๐Ÿ˜ž
It's so original and undisturbed, I'm deciding wether to leave well alone as the stains are small and not visible unless you tilt the seats forward, and maybe cover them with polythene over cloth covers to keep the damp away :roll:
OR hand the seat backs to a vintage upholstery specialist to carefully treat :?
The '49 has such a low mileage the seats are otherwise perfect time-warp :wink:
George don't rush out for a trailer yet ๐Ÿ˜ฎ
My decision on this after looking at the seats over the weekend is to leave well alone ๐Ÿ˜Ž
The covers are so well made and were perfectly stitched and fitted over 60 years ago that I'm not going to mess with them.
It is certainly a job for an expert I feel. If the car were more well used and the seats far less perfect, I'd consider it. As it stands there is far to much to lose should things go wrong.
Stains like this have to be considered part of an extremely original untouched car. Otherwise at what point do you consider some restoration to have taken place if you start changing things:?
