I broke the key off in the driver's door lock the other day! The key pattern has a very deep cut that weakens it considerably and, to make matters worse, the key I broke was from a NOS chrome/brass blank we had cut at H.O. and wasn't cheap.
Due to wear in the lock, the key always needed a bit of a 'wiggle' to unlock the door and I'm thinking about replacing the barrel to a) hopefully get a key pattern that's not so weak, b) get the bloody door locked, and c) eliminate (hopefully) half of the sloppiness/wear in the lock, the other 'half' being in the door handle, hopefully.
Any idea where I can buy replacement barrels? I think the original key pattern is 'SG' so I'd like to keep it as close to original if poss.
Thanks.
Andrew
195x Deluxe oval Beetle
Binz Doublecab
