lutty
  • lutty
guys I have purchased a banner 6v battery. Do I need to charge the battery before I use it?
thanks
If you had to add battery acid then it should be good to go straight away.
lutty
  • lutty
the battery came topped up. When I put it onto the car the battery was dead
That will need charging then :lol:
lutty
  • lutty
I thought that I would ask the question just in case it's a faulty battery. Thanks
Harveypj
I guess for mail order a charged battery would be a potential fire hazard.
Good luck with the charge up:smile:
Jules
:smile:
harveypj wrote:
A 'topped up' one wouldn't be all that safe either!!
We stock the nice rubber cased ones and if we send them they go out dry, no question!
gipf
  • gipf
Jules wrote:
How much are they jules? 6 volt.
Marc.
Piet
  • Piet
Marc.
gipf wrote:
I'm interested too Jules.
Do you also stock 77Ah with these dimensions 215/169/191mm?
Proost! Peter.
mooney3019
I picked mine up from banner fuly charged 2 months ago, about £60
lutty
  • lutty
Guy's, just to let you know my problems turned out to be the starter motor bush worn out & not making a good connection. Once I repaced the bush the car started up first time & probably didn't need a new battery as the old one was fine too
