lutty
  • lutty
Hi ala,
I need to obtain a 30hp barrel/piston & ring set for my 1954 oval. Can someone tell me the piston diameter I require or any leads to obtaining a set
thank you
Piet
  • Piet
I'm sure there are lots of VW-shops around in the UK. They carry them, for sure.
Are you looking for flat pistons standard 76,95 mm --> no problem,
If you are looking for the early dished types 77 mm--> problem because obsolete.
But they are still out there somewhere, I'm looking for these too.
Good luck!
BTW 30 HP = DIN/36HP = SAE. Same engine output.
Proost! Peter.
lutty
  • lutty
https://www.thesamba.com/vw/classifieds/detail.php?id=1014099
Can someone tell me if the above piston set will fit my 30hp engine
thanks
thanks
lutty wrote:
sure, thats the reason i posted it matching to your question...
:shock: :roll:
lutty
  • lutty
Thank you guys for the info. I just thought that I would double check details before I strip down engine & have the details to hand to purchase some of the parts
