Further info is that the diameter of the CB dropped spindles is approx 25mm whereas the widest diameter on the standard spindles is approx 30mm.
I can only assume this is a year specific issue?
Above = CB dropped spindle as removed today (approx 25mm dia.)
Above = newly fitted spindle (approx 30mm dia. at the widest point)
Can anyone tell me if these tapered spindles are correct for the car (they seemed to fit with the rest of the knuckle assembly ok) and what I bearings I need to suit them? Also, will the appropriate bearings be compatible with my current hubs?
Would really appreciate any help on this one as I'm rapidly falling out of love with the car, because no job seems to go smoothly 😞
