On a 59 with a stock engine setup.
The hard vac' line between the carb' and the dizzy is loose at the dizzy end. For some reason the fittings just don't seat properly. (I've tried the carb' end on the dizzy and it seats fine so I'm sure its not the advance mechanism port).
So anyone know where its possible to get a replacement, or at least the sealing 'olives' so I can get that to seal fully. The engine struggles when under load and max' advance is only around 24 degrees.
thanks
