:roll:  1513298_651297804908756_1217323659_n.jpg You have insufficient rights to see the content.
Does it work as a progressive set up?
Originally Posted by: JD
Apparently so...IIRC the outers first followed by the central carb at higher revs.
Originally Posted by: lifeintheslowlane
Oh - strange. I would have thought it would be better the other way around, but then I suppose you'd be dealing with what amounts to a massive air leak in the inlet system, so much harder to engineer.
https://www.thesamba.com/vw/forum/viewtopic.php?p=2825306
