Kaizen
10 years ago
Hi all,
Can anybody help me out?, I have fitted a new 6 volt starter motor to my 30hp Bug and I now need to change the starter motor bush in the bell housing, has anybody got an extractor tool to help me remove the old one? I am willing to rent, buy or borrow your tool to use just once, I live in the midlands, the 6 volt set-up is smaller than a 12 volt unit, I am very happy to return your tool after I have finished the job
I am willing to collect within a resonable distance or pay for the postage if this would be better?
Cheers all....
David
10 years ago
They aren“t horrifically tight in the gearbox IIRC. You ought to be able to tap it out with a suitably sized piece of metal and a hammer.
10 years ago
I assume the engine is still in the car, otherwise it's so easy you wouldn't be asking...
I've heard a lot of people use an m14 tap and start to cut a thread into it, then put a bolt into it and pull on the bolt. Remember to soak the new one in oil over night before you install so it absorbs a bit, then wipe it dry before installing.
10 years ago
Originally Posted by: pre67vw
Spot on Rob. M14 tap does the trick. Haven't had to do that for ages.
