2splits
  • 2splits
OK, I'm stuck.
I installed my "turn-key" Okrasa yesterday, and when I installed the linkage, I found that the linkage would not reach both carbs. I extended the linkage as far as possible, but I cannot quite reach.
Any ideas?
Can I adjust the carb somehow to make it reach the linkage?
HELP!
Kevin
-51 Split Rag
-58 Ghia Cab with Okrasa
-57 356
Andy Sparks
I have a linkage here do you want me to measure it? see if yours is the same?
Actally silly question, will do it tomorrow, my tape is outside, and i'm warm in here.
You sure you have the bracket in the right place?
2splits
  • 2splits
"Andy Sparks" wrote:
Yes PLEASE.
Which bracket?
Kevin
-51 Split Rag
-57 356
joe h.
Mine is about 241/2" from end to end.
1954 oval
2splits
  • 2splits
Yeah, mine too. About 25 inches fully extended.
So, do I need to change this piece on my carb?
 11712.jpg You have insufficient rights to see the content.
Kevin
-51 Split Rag
-57 356
Andy Sparks
the triangle bit should be welded onto the fan shroud.
2splits
  • 2splits
Yeah, thats fine.
If I measure the rods that go into the carbs, at the longest point, they are 25 inches. I'd guess the spread on my Okrasa is 25 3/4.
Kevin
-51 Split Rag
-57 356
Andy Sparks
Find a longer long nut? or get another one and put a thread down it?
Just a thought.
Do I have the same linkage well mines Mr Wobs?
Sorry to hijack the thread, Andy, saw on VZi what happened, hope you're Ok ! 😞
Andy Sparks
"SDV" wrote:
I'll live, look like Adam Ant with a yellow stripe at the moment.
19zwitter52
Does anyone make the Okrasa linkage? Any help would be appreciated.
Andy Sparks
Yeah Steph but he is a hard man to get a hold of.
Hello-
I've never contacted this indvidual, but he advertises Okrasa and Denzel parts.
Denzel Parts
Okrasa Parts
Good luck,
Paul
Paul Vickerman
Go Bruins!
