  • harveypj
  • Stock "Wolfie" Smith Topic Starter
My 58's hub caps should have black 'VW' in the centers.
Anyone know the best way to do this, I'm not sure what method will give the best results :?
Masking will / would be to say the least 'tricky', could brush paint, also thought about over spraying the whole badge and then using a thinners soaked cloth, wipe away paint as neccesary......its going to get emotional I feel it in my bones.
Could always leave them all chrome I suppose
would be greatfull for any advice
Enamel and a paintbrush and a steady hand I would say.
  • harveypj
Cheers JD, Thats what I figured on doing,
just thought I'd ask incase there was a particularly effective technique, the type you normaly find out about after the event.
Oh, I expect that'll still happen!
"harveypj" wrote:
I have painted some in the past by hand too and they looked fine ( I have a steady hand) but I am going to try this method next time as someone suggested this to me also and I have 3 in original paint (copper red) so am just painting 2 to match those. I think the trick will be to spray very lightly! We have some originals with black vw logos here and the paint is thin, I am not sure whether it is age or wear or they were like this originally?
So long as you have enough paint if it does'nt work you can just keep trying! I am not quite ready to do mine yet.
Ovalbug
I did the same job recently on a set of 4 for my Ghia, I tried the spray paint on and wipe off with a rag method, but it was a disaster :lol: .
Ended up stripping all the paint off and starting again..............
For me, best results were obtained with a tiny natural bristle artists paint brush and some gloss enamel; the results are pretty darned good even though I do say so myself.
I'm naturally not artistic at all but it was a rather therapeutic job :wink: .
'63 Karmann Ghia RHD
'72 1302LS Karmann Cabrio RHD
just thought I'd ask in case there was a particularly effective technique, the type you normally find out about after the event.
"harveypj" wrote:
Just seen these...
'50 Karmann
Just seen these...
"pre67vw" wrote:
Ilooked at those Rob,i think they are a very good alternative.
But what about the grooves in the bumpers :roll:
Just normal paint.
Last time I did it, I sprayed the entire center of the cap. No masking. Let it dry for 10 minutes or so, then come back with an rag wrapped around a block of wood and a little acetone. Everything wipes off but the paint inside the emblem and it turns out great!
ps: clean logo inside first with acetone and allow to dry first!!!
surrey67
Just seen these...
I bought a set of these and was very very disappointed they dont fit right @ all save your pennys :roll:
1967 Westfalia SO42
_______________________________________________
Phil
stock 63
Thanks heb623 your tip worked great the nos caps for my 63 now look spot on
Thanks alot tips like these are what a forum is all about
No thanks!8)
I am glad I could be of any assistance!:wink:
I often speak the truth but nobody believes me!!!:lol: 😳 :shock:
